Recently purchased a Canon MB2720
Do you believe these homemade refill tools pierced the silicon plug at the back of the cartridge output port? Wouldn't cause problems?
I'm fairly certain the pink homemade tool I made is too loose. It doesn't seal at all.
Try to shrink some tube around it to enlarge the diameter (heat shrinkable tube is used to protect/insulate electric wires).
Good idea thanks. I'll try this.
I use syringe needle tops which I cut down several of them and they have served me well, it fits into most cartridges, and if you’re having a problem with yours then try pushing it in a little firmer and that will hold the seal..
I got a half dozen new refilling clips from OctoInkjet and found I had to cut some of the tip off because it was to long for some cartridges, but the homemade one worked just fine..
Capture77.JPG Capture.78JPG.JPG click to enlarge..
Thanks @The Hat . I did the same thing. However my refill tool is too loose. @palombian suggested using heat shrink tubing to enlarge my tools diameter and create a tighter the fit. I'll this next.
Sorry to bump an old thread, but wondering if you guys could comment. I followed the Octopus video method for refilling the OE PGI-1200 through the outlet port, then swapped out the ARC chip and everything seems to be working fine. Two questions:
1. In other refill videos, people plug the air vent hole above the outlet port but the Octopus video did not do this. Is this necessary and what's the purpose? I'm assuming the air vent is connected to the back side of the internal ink bag that's inside. Wouldn't plugging this hole just impede the bag from expanding/contracting?
2. What's the purpose of taping the outlet nozzle after a refill? I skipped this step and it seems to work fine.
2. What's the purpose of taping the outlet nozzle after a refill? I skipped this step and it seems to work fine. :thumbsup
There is no need to cover the vent hole, but when refilling inset the syringe into the outlet firmly and suck some air or ink out to equalise the inside pressure then push on the plunger and inject your ink.. Then withdraw the syringe slowly. Wipe up any excess ink..
Thanks, that's what I did and it seems to work flawlessly for now. I'm guessing even a little bit of air in the cartridge is ok since it would just rise to the top. It's the internal spring that is adding negative pressure which I think is important.
Interestingly I have been running those standard refillable cartridges with pigment ink and discovered over the course of months, that the print head was slowly leaking ink through the nozzles even when not in use. Likely due to the fact that the print head is designed for the extra negative pressure in the cartridges.
Over filled carts can usually cause leaks to occur or air where it’s not supposed to be, OEM carts are better at handling issue like that.. my nemesis is always the Feckin Black, but it settles down after a while..
P.S. Must learn not to over fill the cart next time..:old
Nope, these refillable cartridges at only maybe 30% full and still leak ink through the print head. It was not immediately obvious...took weeks/months, but sure enough there was enough ink dribbling out that it would make small pools onto the paper feed mechanism and even seeped between the colors since it was accumulating at the head. It was very suspicious because I had filled these to maybe 50% full initially months ago, but they seemed to be losing level relatively quick especially considering that I barely print anything. I really hope that ink didn't make it's way into the waste tanks and needlessly filling those more than normal.
So I suspect the negative pressure from the spring mechanism is important at maintaining the correct balance pressure in the cartridge.
Not sure if aftermarket cartridges have the same spring + plastic bag...I suspect they likely must have to in order to work properly.
Back
