websnail said:
Already done this aspect of things and noticed something interesting... the bag inlets/holes are designed in such a way that if you empty the bag, the bag material closes over the inlet holes in such a way so as provide a quite effective sort of lid.
In other words, it's a crude check valve. No, that can't be what's doing it, because it works in the wrong direction. It might slow
removing air from the cartridge, but it won't prevent air from going back into the cartridge. I suspect that you had enough moisture in the pad to retard the return of air. From the description of the pad, I doubt that a really dry cartridge could hold a vacuum for more than a second or two. I just thought it might be something to keep in mind. Hopefully it won't happen often.
