- Feb 24, 2005
- Location
- North of Boston, USA
- Canon i9900 (plus 5 spares)
CollegeDad71,
I warned you that color management wasn't easy. You will have to do a lot of reading and experimentation to understand it, but here is an explanation for what you see when you print the test chart.
1. The following image shows a comparison of the sRGB and aRGB color spaces vs. the color space of an i9900 with OEM inks and Photo Paper Pro paper. I used www.viewicc.de to generate these images, as it allows you to upload your personal profiles and compare them against other profiles. The top part compares sRGB (colored area) with the Canon printer profile for PPPro and OEM ink (wire frame). There are areas of sRGB that the printer can't reproduce, but there are also areas of the printer's color space that are outside of sRGB. The bottom part is the same comparison, using aRGB and the same printer profile. Since my camera can be set up to generate images in aRGB, the larger color space shows why I work in aRGB, - my prints have the capability of a wider range of colors than if I set my camera and PS for sRGB.
If the printer's color space is larger than the source color space there isn't much of a problem, since the printer can print the colors as they exist in the source color space. Obviously, there is a problem when the printer's color space is smaller than the source color space. This image shows the same test image in sRGB, aRGB and the Canon profile used above (the image has an embedded aRGB profile, and it may need to be viewed in PS {or Qimage} to see the differences in the first 3 charts). However, the 3rd chart clearly shows that the colors are expected to be different for the printer, as the printer cannot produce the extreme colors. I believe that this is what you are seeing when you print this test chart. How do your "standard photo prints" look when they are printed? Since most photos do not approach the extreme colors, they normally look much closer to the display than the test chart looks.
One more point - when you convert to a new color space, there are several options (called "Intents") that change how colors near and outside of the limits of the printer's color space are printed. The following image shows the two most commonly used Intents - "Perceptual" and "Relative Colorimetric" (there are also "Saturation" and "Absolute", but they aren't usually used for photos). It can be seen that this setting also affects how the image is printed.
Read the references in my previous post and chase down the links that they give - it will take a while before all of this strange jargon begins to make sense.
