hi everyone-I have for years used MIS Associates CFS for my Epson 1280. Always had good results until now. a month ago, I tried re-filling my Magenta tank with new ink that I had just purchased from them. (I am using the Archival inks.) shortly thereafter, the Magenta Nozzels stopped printing.
I went through all of the instructions: restored the nozzle patterns using Epson cartridges. ran the Purge cycles etc. even though I would get a good nozzle pattern, as soon as I try to print an image, the Magenta bands, then doesn;t print at all.
I ordered a new cartridge from them. had the same results. had my printer serviced, they said they found no problem. Indeed, with an Epson stock cartridge, I can get a good print. but when I install the CFS , the Magenta won't print.
I called MIS, I suggested that perhaps it is a problem with the ink. so I ordered another new cartridge and a new tank of Magenta archival ink. I also ordered a brand new Epson 1280 printer.
I just set up the new printer tonight. it worked fine with the stock cartridge. I installed the MIS pre-filled cartridge. followed all of the procedures, which i am quite familiar with by now, and everything worked fine: untill the second print. once again, there is no Magenta. the Nozzle patterns are exactly like they were before.
My question to all of you is: have any of you worked with these guys? and if so, have any of you had problems with the Magenta Archival Inkjet inks for the CFS for Epson printers? I don't know what to do, I have spent copious amounts of money and still can't get my projects done please help!!!!
christine
christine
