swisscow
- Dec 11, 2021
- Canon Pixma Pro-1
Hi printer fans
I recently bought a barely used Pro-1 almost for free. I knew that getting this box up and running again won't be easy sailing but saw the challenge in it and got it. I've now had already couple of successes but still it's not working as expected and I'm wondering if any of you printer pros can provide me another hint in my quest to get my Pro-1 going.
. Thank you guys in advance!
- From the guy I bought it from I learnt that the printer is outputting a 6700 error. I read in this forum that this might be related to the internal coin battery so I thought it might be easy to fix the printer.
- Replacing the battery, however, didn't make a difference (and, yes, I replaced the battery while the printer was switched on, as advised multiple times by @The Hat
). - When turning on the printer, it's not doing anything except flashing orange-white (resume-power) alternately 26 times.
- Now with the following sequence of button presses I managed to get into service mode: press and hold resume, press and hold power, release resume, press and release resume 3 times, press and hold resume, release resume and power button together. The printer is then doing some initialization routine while the white power led is flashing and then the white power led nicely stays constantly up.
- Now I've tried to connect to the printer via the service tool but I didn't have success. I tried both v3400 and v5103. I just get an error code 006 from the service tool.
- Then I read that you can also release some service mode commands from the printer itself via a series of button presses. I found out that when pressing and holding the resume button the power button starts to blink and no depending on how many time the power button blinks until the resume button is released again, a specified function is run:
- release resume button after 1x power button blink: the printer is doing something, cleaning maybe?
- release resume button after 2x power button blink: the printer is printing the nozzle check
- release resume button after 3x power button blink: nothing
- release resume button after 4x power button blink: the printer is printing another test page (with small rectangles of the different colors) and then the resume button is blinking 11times in a row (this is probably meaning that the nozzles are clogged, also the nozzle check is not giving a perfect output). The error can be confirmed by pressing the resume button
- release resume button after 5x power button blink: a white page is output(?)
- release resume button after 6x power button blink: a white page is output(?)
- But also from service mode I can't send a page to be printed neither from my Win10 PC nor from my Ubuntu desktop (with the TurboPrint driver). The TurboPrint dialog is giving me the 6700 error.
- Do you have any other suggestions/tricks I could try to get this printer going again?
- After turning the printer off when in service mode, I can't turn it on anymore via the power button. I then need to unplug the power (and leave it unplugged for a minute or so!) and then, after plugging in again, I can turn on the printer again. Is this the normal behavior?
- Nowhere in this forum I have read about the possibility to issue service mode commands right form the printer via button presses. Is this something you guys did not yet know? This could probably help other guys as well.
- According to the guys I got the printer from, it has been sitting around unused for at least 2 years. Now after that time for sure the nozzles are clogged but with every clean cycle I do (run with the button presses from the service mode) the nozzle check looks better. Now my understanding is that currently it would not be worth buying new cartridges, right? Or could it be that the clogging is the only problem and if I would replace the cartridges, the printer would communicate again?
- Would it be worth trying to find yet another version of the service tool and see if I can connect with that? Could it be that I was using a wrong service tool? Could anybody maybe share a link to a service tool that you know is working with the Pro-1?
- So far I was connecting to the printer via USB. Would it be worth checking via Ethernet? Or maybe even checking the direct printing from a camera via the PictBridge?
