Problem with ip 4500 cyan cartridge
MACHIAVELO
A greeting to all foristas and happy 2009
I learned a lot in this forum, I have 4 canon ip 4500 photo and printing inks surcharge OCP with the German system, the problem that when sending a series of 10 or more sheets of printing on photo paper in 3 or 4 leaves me in the top of the picture on the far right and far left a stain 2x3mm.Luego when I pause the printer for this error, and let rest for 5 minutes and start again o5 andalusia a3 sheet produces the same error,
Cartridge compatible produces no error
Thanks already
Xalky
If a compatible produces no error then the answer is, you have a bad cartridge. the vent hole could be clogged. Sometimes the sponge in the cartridge outlet is pushed into the cartridge which prevents it from making contact with the screen on the print head. I've had limited success by pulling the sponge plug out ever so slightly with a couple pins/needles. Your cartridge might need to be flushed out if it's been used many times.
MACHIAVELO
This was exactly the problem, discard the defective cartridge, since I could not repair it as you advise me, and I have taken another cartridge (including a vacuum-compatible) and has worked wonderfully.
Very grateful for your help.
I am in orders for those who need it
