Bentley
- Sep 26, 2024
- Canon Pro 1000
Hello,
a little topic how you can recycle your the waste ink collector
First of all put your safety gloves and glasses, be careful
First drill a hole at the left side, not to deep otherwise your drill bit will blocked in the inner layers
(take the drill bit from your hole saw)
I have take a 44 mm (1-3/4) hole saw
If you have a fine tooth hole saw it will be easier to drill the hole
don't let exceed the drill bit to far out of the hole saw
(drill bit can blocked in the inner layers)
Drill the hole and take a screwdriver to remove the plastic
remove some plastic parts
with a pince long nose pliers put out the inner absorbent layers
the first one is not very easy to put out
there are 4 of them, be careful they are full of ink
Rince the collector with water, check of there are no leaks normally the tank is waterproof
Let it dray and tape the hole
You need to reset the chip and you are ready to go
