Printing PVC ID-card with color management
Recently I bought an Canon TS705 printer, because I could not find a suitable ID Card tray for my Epson SC P900 printer (despite it supports printing on CD/DVD discs).
Unfortunately the standard setting by the Canon printer was suboptimal: colours are washed out and greys have a brownish look, despite using original Canon Chromalife inks with the setup cartridges.
So I generated a 140 patch target to be printed on 2 PVC printable ID cards:
As you can see the greys are indeed printed with a brownish hue (color management: off).
See here the effect of the special profile on the picture below: upper card is printed with the standard Canon setting (color management done by the Canon printable tray driver) and the lower card is printed with colours corrected with the specially made ID-card printer profile:
Lothman
colours are better but the background of the man with the Cello and the stairway get too dark and drown in deep blacks
Unfortunately the photo is not optimal with my smartphone. A scan might be better:
The shadows of the staircase are indeed crushed together, but the man with the cello is what it should be when I compare the picture printed on glossy paper (larger gamut and deeper black) with a higher count profile (918 patches), with a dark background. Don't expect wonders with just 140 patches, but most importantly the colours are now right.
Arrow88
Print Lurker
Canon 705a
I recently purchased the same printer and have the ID tray on order. Would you mind sharing what software and setup is required ?
Also the specially made printer ID profile you used above is that something that’s inbuilt or something you could share.
Thanks
Thanks
if interested I can send you the profile. Please send me a PM
