- Thread starter
- #11
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
another trick is to carefully position your paper and do the printout then repeat the same thing again and print over the same image !
No in fact use it straight away otherwise the paper will stretch too much, but on the paper you are using it wont be worth while..I guess that when using this technique, the paper should be allowed to dry between prints?
It’s a good job you didn’t; you would have gotten the same results with that printer too, Ouch.I'm glad your managed to narrow it down for me because I was so close to going out and buying an Epson R3000
