- Thread starter
- #11
theweesparrow
- Feb 9, 2022
- Epson SC-P600 Epson ET-7550
I'm happy to hear anything constructive.
Ok..... So you said that your current Eco Tank printer can only handle 4-5 before it "Grinds to a halt"?Happy to hear suggestions.
Hi, Jose,Ok..... So you said that your current Eco Tank printer can only handle 4-5 before it "Grinds to a halt"?
Could you elaborate on that?
I am trying to figure out what would cause that.
I think the ET8550 would serve well.
Keith Cooper who has probably done the most extensive series of tests has shown how well. it performs with greeting cart stock.
Inks even original are probably the lowest you can get. So printing cost should not be an issue.
How good are these inks?
Well they are not going to be the best dye EPSON may have produced.
But from a performance level they seem to do a very good job.
On average here in the USA 70ml bottles go for about $19 which is a bit more than cheap non OEM equivalents.
I think there might be something mechanically wrong with your current ET printer. It should be able to print and print.
What Canon laser do you use?Hey, I use a very similar 300 GSM creased paper by Felix Schoeller Tech Papers, but I went with a Canon color laser printer for greeting cards, and I haven't looked back. I also created my own ICC profile for the paper, the results are quite surprising. The OEM toner is dirt cheap in comparison to even OEM inks. And the speed--no comparison.
