- Apr 19, 2007
- Location
- USA
- Canon MB5120, Pencil
https://www.lcipaper.com/kb/calculate-convert-paper-weights-on-your-own-website.htmlI don't know what 60lb paper is
60 lb matte photo paper?
The calculator has presets on the type of paper being measured, but may need a custom paper dimension for the Red River paper to be most accurate.Redriver spec's the paper as 60lb/232gsm , but the calculator tells me something different 60lbs - 162 lbs ?
Wow The kettle calling the pot black.. I use feet to walk with, but millimetres to measure with.. No one complains about ounces when it’s in Gold…Pound weights are per ream so it depends on paper size and they can't even exactly decide on how many sheets there are in a ream.
Great. Thank you for your continuing and very patient insight! I very much appreciate all comments on this thread.I just printed 25 photos on 4x6" paper - in one go , on 300gm paper glossy , that's more than yours - 'At 11mil thickness and 232gsm, Premium Matte Plus ' which is specified as a 232gm paper; at least 30 sheets should fit into the input tray.
Redriver spec's the paper as 60lb/232gsm , but the calculator tells me something different 60lbs - 162 lbs ? Which preset is to be used in this case ?
Anyway . such a paper should run without a problem.
Edit:
No, but they do if they complain about filing their dental cavities with ml's of molten hot gold.No one complains about ounces when it’s in Gold…![]()
