Printer is printing only half of the postcard
How is the printer connected - with a longer USB cable
Good point.
Another: Is the OP using WiFi to transmit from computer to printer? If so then use only a proper USB cable connection.
Some times this trick actually works.
True, and I would recommend as well, but you still made me smile with your backhanded complement to Tech Support. :D
Andrej
EPSON
Guys, thank you very much for all your inputs. I talked to Canon helpdesk and they confirmed that problem exist due to the connectivity, hence need to use cable and not wifi.
Thank you for the follow up.
@Andrej Thanks for the feed-back and out of curiosity: Did you use USB or LAN connection to solve the problem?
