Primera Brave se , refill
gizmo1
You can now get a Continuous Inking System (CISS) for the Bravo SE and for the Bravo Pro
We have one on our bravo pro and the cost savings are high
we purchased it from eBay but you can get it directly from the company that developed it at www.jpldisplays.com.au
If you "Steam" off the colored bar-code located on the underside of the Primera cartrige and attached it to your full 3rd party ( cheaper ) Lexmark Cartrige in the same position, it will be recognized by your Primera Bravo.
I made a little mylar tab that contains the bar code and just double sticky it to the 3rd part Lexmar and use it over an over.
Works perfectly
videonet
Hi Pals, Ill tell you about my experience in that, I have two Bravo 2, I do myself the refilled cartridge very clean, in black cartridge take off the sponge, clean with water until the water clean the old ink. Dry with cold air. Then load the black(DYE) ink.For the color, the first time use destilled water to clean each color sponge, so the new ink do not contaminate the original ink. For the bar code, cut the plastic from original cartridge, then scan bar code in 1200 DPI, retouch with adobe photoshop to fix any pixel dark or bad.Then make a template in corel and print in glosy photo paper. That is OK, but the problem, that agree with "jtoolman" about that issue: (them the code is already recorded either in a chip in the printer or on the driver so it can count down your ink use), because mostly times recognize well the refilled cartridge original with "new bar code" or original bar code, but when try to print bar test after clean in "cartridge maintenance" do not recognize the same cartridge. Some time in this case take off the black, change the print setup for color only, and some time work ok. If I put the same cartridge in another Bravo 2, maybe work OK or do not recognize. So I think the firmware memorized some data about the cartridge. For fix this issue download the program "FirmwareDPIIv1.29_1.43.exe" and loading this erase data(im not very sure).Also recomend to download this program to test all the printer and adjust it. "PTCalibration1.2.exe".By the way the bar code I made are identical than the original, but there are only way to paste well, so Im trying to discover the trick.Take in mind to refiil before the ink be in 10%, if you dont the fuse cartridge burn out.
Any new suggest welcome
Also must to recognize that the Primera bravo support work great with the customers
Mike.
Dave Rowly
Primera Bravo SE
Hi all sorry to bring up an old thread. I have looked all over the internet & this seam to be the only place talked back the printers ..
I have a 53332 for my Bravo SE. The cartridge got to about 48% so I refilled it at this level so i dont go to low and blow the fuse, I put back in & its still showing the same level ?
Can anyone help me here
lh.vandersteen
primera disc publisher se
hello I have also a primera disc publisher se with cartridge 53332, but I can not find a bar code on the under side
witch Lexmark cartridge is working or is there a compatible one
Dave Rowly
Primera Bravo SE
The SE don’t use bar code & you cart use the Lexmark ink the se.
Just the orgainal & refill and put up
With the nag screen every disc
lh.vandersteen
oke thank you just refill it wit Lexmark ink do I need special Lexmark ink, and what do you main with the nag screen every disc thank you
Dave Rowly
Primera Bravo SE
After every print it will pop up on the screen to press the button on the top on the bravo SE. Then click no on the screen of the computer !
lh.vandersteen
ok thank you I have searched here in the netherland for Lexmark ink but I can't find is there a special website where I can buy the inkt for this thanks for al the help
Dave Rowly
Primera Bravo SE
Just any ink it don’t have to be Lexmark
Edit:
