- Thread starter
- #11
Thanks again, Stratman. As mentioned in my #1 post, I would first like to clear the possibility of an electronic failure - for the Pigment Black, before investing any time in the color nozzles. You mention a worst case scenario of a failed logic board - if this was so, would it mean the end of the printer, due either to the non-availability of the part or its excessive price ? Or, could it also be due to a failed print head - which would probably cost almost as much as the printer originally did.stratman said:I see the top portion of the Pigment Black nozzle check is missing. Also The Cyan had a clog that cleared after print head soaking. You also developed a problem with Yellow after soaking, which could either be a clog or ink starvation from a malfunctioning cartridge (vapor-locked, so to speak, not letting ink exit the cartridge, and may require a flush of the cartridge.). Until you get all the dye inks to print properly in a nozzle check, including the now problematic Yellow, then do not print anything but nozzle checks. Same goes for the Pigment Black ink.
The Yellow problem may clear after more soakings. The Pigment Black, however, may be a malfunctioning print head and not just a clog since there appears to be a symmetrical complete loss of ink. The absolute worst case scenario is a failed logic board assay, which is supposed to display an error message.
I would still attempt further soaking as the cost is negligible compared to the price of a new print head. You might even run tap water down onto the bottom or top of the print head to try and dislodge and clear a clog. How long might soaking take? One day, two days, three days,...? No one can say except your own patience level before either the supposed clogs clear or you have had enough and buy another print head.
Unfortunately no workaround besides what you've already tried. Interesting that the printer overrides your paper selection and defaults to pigment ink for the EEPROM print out.erpp said:Cant figure out if the information about the waste ink level is among the printed lines
Any way to work around this, and get the whole report printed ?
 If you want, post the EEPROM image.  Maybe we can still extract some useful information such as number of pages, pictures and disks printed out and get an idea how much your printer has been used.  Since the 4500 is a great printer that is easily refillable, I would want to continue using it till it died, so I would buy another print head while still working with the problem print head.  If you get the print head working again then it could be stored for future use using Pharmacist's recipe for storage fluid.  If you get it working before installing the new print head, then you can store the new one for future use.  Worst case scenario is you never need the new print head and you sell it for a premium since they will be phased out for manufacture in the future.
