- Thread starter
- #11
Hi GHWELLSJR
The UK car window cleaning agents are definitely not ammonia based, but detergent (I think).
Your advice is that I should be patient and allow more time for soaking the purge system to work.. so I propose to try leave ammonia sitting on the purge pads, just keeping it topped up for the next week or so, and perhaps run a cleaning cycle each day. I think that I should allow the print head to return to the purge pads after each top up to prevent the bottom of the head from drying out.
Does this sound sensible?
I will post again in a week or two weeks to report on progress.
I had one other thought- the larger of the two purge pads lifts away easily revealing a very shallow tray with four small holes- I assume these are the drainage points, and also the channel through which the purge pump sucks away the ink.
I should be able to work out which drainage hole corresponds to which colour of the four photo inks by looking at the nozzle positions on the print head and figuring which one sits above each hole.
As a last resort, I was wondering about either applying compressed air or a very careful mechanical reaming of the yellow hole with a fine, flexible augur (perhaps a strand of copper wire).
Thoughts (or dire warnings) would be appreciated.
Hi LIN,
You suggest an electrical fault on the print head. But I just replaced this a few weeks ago, when the printer originally developed this problem.
Many thanks to all for the support,
Jon
Hi LIN,
Jon
