- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
Use the "Prevent Paper Abrasion" opten as mentioned previous in post #8..
It is ok to use it all the time, and yes it does say that Print quality MAY be affected, but it rarely does, and profiles have no relation to print problems such as these.But is it OK to use it all the time? Because when I use this I get a warning that the print quality may be affected.
How do I get inside there? Just open the lid and spray from there or... ?but first give the whole area around your purge unit a good spray with window cleaner and mop up the remaining liquid with paper towels
Yes, and use a flashlight to see more clearly..Just open the lid and spray from there or... ?
Usually Canon includes installation instructions with diagrams on how to initially setup the printer which includes installing the print head. If you threw them away then here is a video of the initial install procedure. Installing the print head is at the ~2:00 mark.I found some videos about removing the print head of other Canon printers and it looks fairly simple.
