- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
This is what you normally see when you go to run a nozzle check, but if you read the section under the bad nozzle pattern it clearly says how to clear the issue without damaging the print head, but these instructions are mostly missed or not read at all..
Click to enlarge..
Quote” If the printed pattern does not improve, even after cleaning is executed TWO times.. Execute Deep cleaning.. “ !
Any more than one deep clean is a total waste and may cause the loss of the print head..
Wait overnight and try again, because impatience can be very costly…
P.S. How many of us have actually read this little message.. ! !
Click to enlarge..
