- Jun 16, 2006
- Location
- La Verne, California
- Epson WP-4530
It appears that during the entire course of this thread, you have never had any yellow print out, is that correct?
If so, it may be that whatever contamination was in your previous yellow cartridge has gotten into the print head and caused a major clog. The other possibility is that there is an electrical fault that is prohibiting the yellow to print.
Here's my suggestion: remove all the cartridges and then remove the print head from the printer. Take a piece of paper towel and fold it in quarters. Put some Windex or other window cleaner or just plain water on the center of the thick folded paper towel. Place the print head on the wet paper towel and press down gently. Look at the inlet ports on the top of the print head. You should see some movement of liquid as you press down. See if you can see this movement for the yellow inlet.
Put everything back together in your printer. Let us know what happened.
Also, you haven't indicated what the prior history of this printer was except that it was refurbished. Can you state that the yellow did work properly at some time in the past?
