My new Canon Ip4920 @ Dominican Republic
oroblec
Dominican Republic
Canon pro-10 - Epson L1800
This are the best Setting for print DVD Cover or family picture but is eating all my ink so fast that maybe some guys can tell me what to change and have same quality here we go with my setting view.
Cover or Family Picture 8.5 X 11 page Size.
This setting is for my DVD Disc Verbatim hub printable.
So what do u think guy i should change for the ink doesn't go that fast.
Change Print Quality from High to Standard to use less ink.
I don't use the CD/DVD software that Canon has. I found it limiting. Instead I have been using Acoustica CD Label Maker. Currently, the template for one of my main DVD hub printable discs has an outer diameter setting of 118.70 mm. If you cannot alter the dimensions in your current disc printing software then it is time to find a different one.
oroblec
Dominican Republic
i'm with u Stratman i'm using Surething and works great just trying to find a method where normal people can print in canon software withougth isues and help others.
oroblec
Dominican Republic
Hi all and new year 2013 now i'm here to talk about the canon ip4920 i'm been using it during 1 year and 2 month and it still rock i'm been reffiling it for during that time i just got the first oem cartriges and after that refill method with mapsy clean cartirges auto-reset and hobbicolor ink i will try to change it just to do more business with mapsy the only problem i had got with my canon is the last 2 weeks when i reffills the tanks i get one lamp off with not ligth i ned to unplug and plug like 16 time b efore it reconise i pm mapsy to see if he got some idea how it can come work as normal but after all is a good machine and still rocking.
You have two alternatives one is to get a complete new set of ARC chips and replace your current ones.
The second one is to get a resetter and use the chips from your original OEM cartridges on your current ones.
Just to be the Devils advocate you could also get an empty set of 521/221 carts fit your 225 OEM chips on them
and armed with a resetter, then all your trouble would be few.. :)
