- Thread starter
- #71
palombian
- Feb 4, 2014
- Location
- Belgium
- PRO10,PRO9500II,MB5150,MG8250
Got off the phone with someone trying to explain how ARC chips work and people always THINK there are real sensors in the cartridges.
I gotta repeat.....people just need printers that when the ink runs out, they stop, then fill back up and to hell with what the chip says.
Long time ago, I indicated that these machines have sensors to detect ink inside the printhead. I think Hat found out himself that these sensors work. So darn!...forget about chips with these transparent carts. Fill the carts when you are done and top off when necessary and just let the printer run and run till it is out of juice. I think that is the printer we want....this chip nonsense about ink levels which are all FAKE anyways.
I tell you, there are more issues about CHIPS and its related functioning in refilling than ANYTHING else. To Hell with Chips especially Epsons. This is where the Maxify is the hidden gem provided you can get it running like a clock. Mine has.
Agree on the chips for the Maxify.
When starting with this printer I wanted to explore 2 solutions:
- transparent carts without ink monitoring: in this case almost any chip is OK, and the one-times who stay in an unknown state (?) are maybe the best (although mine kept this ? while the ones of @The Hat went to X and I suppose he had to push the red button, and we don't know the long time behaviour of the printer in these situations).
- refilled OEM's with ink monitoring (ARC's or one-time): in case the refillables did not handle the ink as they should.
In particular with the high capacity 2500 carts (40 and 80ml in the refillables without leaks etc) the ink level should never be a concern.
But maybe the bag of the "old model" 2500 is too small to compensate pressure changes and could cause the contamination observed by @The Hat , @Redbrickman and myself, and the 1500 @mikling uses does it well.
Anyway, the "new model" seems to be much better.
My printer must behave in a home/SOHO environment, not a production one.
Since I paid for ARC's I wanted to test this option, not sure if I will need them.
I only have to find out now why I need to clean the cyan so often to have my Maxify runnung like a clock too
