Do not waste time and effort if the printer is under one year. It needs to have some mechanical work performed and if it is still on warranty, take it in immediately.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Assuming that your purge system is working, based on your prior statements, the question we have been trying to resolve now is whether you have an electrical problem or an ink flow problem. If it is correct that once this problem started happening, you have never, ever, not even once, seen any black printing on any nozzle check, and if it is correct that you can see moving black ink on the inlet port when you do the blot test, then this is pretty conclusive that you have an electrical problem and you will need to get a new print head.tcsnyc said:Blotted the print head on both the inside and the bottom and ink came out. Seems to be flowing OK. Put everything back together then tried again and the bottom of the nozzle had a good amount of ink this time. Im really confused about this. It stopped working when a blank ink cart ran out, and as I have mentioned before its not like it only prints partial black, there is no black at all coming out
