- Thread starter
- #21
Since you have reported that the dye-based inks print out perfectly then there is nothing wrong with either their purge pad/tube nor that portion of the print head for the dye-based cartridges.themow said:if both pads or pumps are defective, would the ink still look fine on the nozzle check but the pigment be non existent
You should NEVER try to force fluid of any king through the print head whilel in the printer, even more so with the printer turned on!themow said:with no power to the haed should water flow through the pigment section of the head? I had a plastic tube attached to it and the water level never changed. The dye portions flow when performing the same test
Keep us appraised of your efforts.Cleaning: fill a cartridge with this solution (with ammonia) and execute a deep cleaning cycle to remove stubborn and tenacious clogging.
20 ml isopropanol (isopropyl alcohol)
80 ml distilled water
10 drops of propylene glycol
Ammonia Concentration: if used in cleaning cycle stick with 5 drops per 100 ml and when used to soak printheads externally increase it to 20-25 drops.
Fold a paper towell into a nice thick and even strip and drench it with the cleaning solution and put it under the printhead and let it soak for about 1 hour. After that, execute one cleaning cycle.
25-30 % ammonia: this is concentrated ammonia. If you use household concentration, increase accordingly.
Standard household ammonia in the UK is 9% w/w (weight for weight)
