- Nov 3, 2004
- Location
- Bay Area CA
- CR-10, i560 ,MFC-7440N
So far, I've been loving my 3D printer... well, everything except getting the files to the printer to print.
At first I had a thousand problems just using the SDcard, for example:
So, I figured I'd try USB, but that's been even more frustrating. I plugged in my printer and my Windows 10 machine recognized it as a generic 3D printer and set it up. I can sometimes get CURA to connect, and was once able to start a print... but since then, I'm extremely lucky if I can get CURA to see the printer, and when it does and I start a print, the printer just sits on the print screen indefinitely... as though the data to get everything ready has started, but no data about the object to be printed is being sent. I've tried connecting via USB with CURA 15.04 and also CURA 2.6.2.
I'm tempted to try and connect to it wirelessly, but that seems like the least likely to work if SDcard and direct connect with USB isn't working.
My printer has the most recent firmware that I could find: 35.110.2
Not sure what to do now
It's just SUPER frustrating having to go back and forth and back and forth with this micro SDcard, especially when 70% of the time I have to do it again.
Any ideas?
- I'd write a file to the card, it showed it was on the card (I could even copy the file from the card to my computer, verifying it was on the card), but when I put the card in the printer, the recently added file was missing. When I put the card back into my computer, the file was gone. It's as though putting it into the printer erased the new file. This happens almost 70% of the time.
- I thought maybe it was a card issue, so I used another micro SD card from my camera. No matter what I do, I can't get the printer to read the card. 100% of the time the printer says the card is empty. I've formatted the card, tested it a hundred ways, and still the same problem. No files found
Any ideas?
