3dogs
- May 13, 2012
- Location
- Fern Hill, Australia
- Epson 3880. Canon Pro 9000,
@palombian said - The Colormunki software allows to use a previously print 1st test chart, but how do you manage a longer dry time for the second ?
On second thoughts, with the Colormunki, at a later date, could you not print a second chart, but use an earlier second chart in the measurement process?
Why not just make one set of charts and reuse? Over and over.........reason :- .because you are charting a dynamic ...............if you believe that EVERYTHING Is as it was, and you dont have any care for the integrity of the current output, go right ahead and reuse charts
@ TheHat....I AM YOUR SON.............and I am the Devils Advocate!!!! ( #2)
Seriously tho, I had a long tussle with colormunki charts and found that in my case time did not drive the reading, it was ink density. BUT results were best (on output of prints) if I allowed 24 hrs dry time for my charts..........however, I always worry about ambient light variations, but then I DO get a bit picky about things.
Cheers
