MG5350 duplex printing
John Wallace
Valencia, Spain
Canon Pixma iP7250 and MG5350,
I have just discovered, by accident, that this printer has a facility for duplex printing. However, I cannot work out why it did it because there is no tick box for double sided in the print dialog box.
So my two questions are:
- Why did it suddenly print automatic double-sided without apparently a pronpt, and
- How can I acquire the missing double-side tick box.
I'm running a Mac on Sierra.
Sorry. I looked at your link but still don't understand how OP's printer does duplex printing without him directing printer to do so via a setting. :idunno
Auto Duplex has meant the printer will print duplex once you've told it to do so (setting selection). Otherwise there is Manual Duplex where you manually feed the paper back through upside down to print the other side.
John Wallace
Valencia, Spain
As usual, I was confused by information on the web. There are two ways:
- in the print dialog box, you set the lower box from the drop-down menu to 'Duplex printing and margin, then tick the 'duplex printing' box.
- Or, on the printer screen, you navigate using the scroll wheel via Copy/Print settings/change paper type to Matte/2-sided
I must have set it by mistake, either on the scroll wheel or on the dialogue box.
All the time I've had this printer, I never realised you could perform duplex printing.
There you go!
John Wallace
Valencia, Spain
I've now written in large writing the following three things on my wall:
1. Switch off, wait ten seconds, switch on.
2. Check the batteries
3. Read the manual
That should solve 99 percent of problems.
Happy Christmas!
