Magneta ink smudging/spreading
raen714
Print Lurker
Canon iP100 Pixma
Hello! I don't really know how to describe my problem in words, but I'll attach pictures. Basically, I'm trying to print out some color documents with my Canon iP100, but the magenta ink is going "outside the lines" and messing up the colors. I've tried two different (Canon brand) #36 color cartridges now and they have identical problems. I've tried several cleanings, deep cleanings, print head alignments, and nozzle checks but nothing seems to be helping. If you look at the pictures I'm attaching, you can see in the nozzle check that the edges of the rectangles aren't crisp, they have magenta ink overflowing the edges. On the print head value page, all of the squares look fine except for the two at the bottom, which have the same problem. Any idea what might be wrong? I used up an entire cartridge of ink already and I really don't want to use up the second cartridge playing with things. They're too expensive to waste that way.
Thanks in advance!
20180315_145253.jpg 20180315_145303.jpg 20180315_145319.jpg 20180315_145328.jpg
kdsdata
Calgary, AB Canada
Pro-100 & Brother-L8900
I would need to ask if you have removed the print head so that you can make sure there are no tiny droplets around the nozzle outlets. I am not familiar with an iP100, so I can't instruct how to do that, but that's the next thing I would do. There are probably videos on youtube.
@raen714, Try giving the timing strip a clean with a paper towel soaked in Windex, and then print another sheet to see if that cured the problem...
