- May 6, 2011
- Location
- Cluj-Napoca, Romania
- Epson L800, 1400; ML-2165W
X-Acto knife
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Coins wear and change weight. If you really want to calibrate a balance (it's called a balance, not a scale), for under $5 at Amazon.com you can buy a very good weight that is accurate to several decimal places. The main reason to check the balance is that weights depend on where you are on the earth. Even without calibration the balance you have may possibly be more accurate than any coin. But yes, coins are good enough to weigh ink in a cartridge.PeterBJ said:Thank you very much Tudor, for the tip of using coins to verify the accuracy of a scale. Coins are made to tight tolerances,....
Thank you for the measurements! The last time I had unopened OEM cartridges I didn't have a precise scale, so I used a kitchen scale and got 35 for the 525 and 21 for the 526. This is much better, will add them to the worksheet.PeterBJ said:The weights are for new Canon OEM cartridges with the orange clip and the vent sealing tape removed:
PGI-520PGBK: 35.3g, CLI-521C: 20.3g, CLI-521M: 20.2g, CLI-521Y: 20.2g, CLI-521BK: 20.4g
On second thought, I guess you're right, although the instrument does balance an electronic force against the gravitational weight of the object.PeterBJ said:I thought that "balance" only applied to the old type of weighing equipment, with two trays, suspended from a beam?
I wouldnt mess with PeterBJ, on a scale of .1 to 10 he is pretty well balanced..ThrillaMozilla said:On second thought, I guess you're right, although the instrument does balance an electronic force against the gravitational weight of the object.PeterBJ said:I thought that "balance" only applied to the old type of weighing equipment, with two trays, suspended from a beam?
As long as people can buy those, er, scales, dirt cheap, I'd just like to encourage them to buy a calibration weight for just a little more.![]()
