Low cost Cartridges for Epson R2400
paradox0123
Has anyone tried the Epson R2400 K4 cartridges sold by inksupply.com. They look like a good deal at $9.95 per cartridge (instead of $16.71 from Amazon). I am looking for a quality ink that is close to the Epson OEM inks.
Manuchau
B.C. Canada
If you have such a high quality, expensive printer, then why mess around with cheap compatible inks and cartridges?
Depending on the volume you print, it may be better for you to use a CIS ststem with high-quality inks. Easy to work with if you get a good system, and very inexpensive to use after the initial purchase,
mtqphoto
Hi,
I have been using them on my R2400 without problems. Their ink is quite close a match to epson's - icc profiles work reasonably well.
Best wishes,
mtqphoto
