- Thread starter
- #11
barfl2
I reread The Hat ideas in particular taking a chip off a magenta and applying it to a yellow cart and then try that in the magenta position. For some reason it did'nt work got the wrong cartridge message. All I did was re-insert the original Magenta cart. There was then a long vigorous clean. The subsequent image is the nozzle check shown.
So what happened? the original bad cart flow suggestion proved correct. What caused it? Freedom method? but then the second cart was a topfill one.
I had hoped the Freedom method would give me a set of undrilled carts but now not so sure. The original Video by R-jettek showed only partly filled cart and I replicated that effect with my adapter and Box type Freedom kit. I think the problem starts with the multiple pumps and generation of a lot of air, but I may well be wrong. Gigigou seemed to show a complete fill but I could not replicate that, but his valve might have been different.
Many thanks to all and hope some knowledge has been accumulated. DRAT DRAT Expensive OEM cart is already on its way
