- Dec 27, 2014
- Location
- Germany
The clogging problem with pigment inks is probably not as severe as you may assume, just print something - small images, color patches whatever on a somewhat regular base, not even every day, and clogging shouldn't be an issue.
Instant dry photo papers create the impression that the print is dry but the solvent is still in the coating and needs a while to evaporate. If you laminate directly you may get an effect of delamination that the upper layer with the ink sticks to the adhesive but the solvent still there reduces the adherance to the base paper
and separates from there and you get bubbles at the end under your lamination. It does not happen equally with all types of papers or not at all or within a few days, you cannot forecast that effect. And be aware that about all refill dye inks give you a much worse fading performance than genuine HP, Epson, Canon inks. And you would need to ask yourself whether it is the best approach to protect fast fading refill ink prints with lamination.
Edit:
Edit:
