Drjim
- Aug 29, 2017
- Location
- Gaithersburg Md
- Cannon ts9020 pro100
To use your printer successfully, you’ll need to refill OEM carts because compatibles are not that reliable and can cause all sorts of flow issues, your set-up cart would be next to useless for refilling, i.e. you going to need a bigger boat, XL’s...TS9020 printing on pro-luster with setup oem carts. Will compare with PC inks later in the week.
All these refills have a negative effect on the chip, if you constantly keep resetting the chip when unnecessary then you can end the life of that chip prematurely, try not to over think this refilling issue, just refill when the reservoir is empty works just fine...Or just top up at will and ignore the indicators until low is declared.
Do you get a warning before that? If so, what level is the ink in the cartridge then?Because "low" on my printer (ts9020) is NOT announced when the reservoir tank is empty (the optical sensor) but sometime after that
Observation how? Have you weighed a cartridge after pulling one and then replacing it back into the print head, shutting the cover, letting the printer perform whatever it does to ready itself for operation, then opening the lid and taking the same cartridge out and weighing it for comparison?And by observation it does not purge unless it's knowledge of the ink level changes.
