Steve J
- Feb 8, 2019
- Canon Pro1000, Prusa I3MK3
1) EE is an Electrical Engineer. I have a Master's in Electrical Engineering.
2) The CR10 is about as big a printer as you can make using the RepRap design. Look at the reviews on the TRex, which is 500 x 500. Problems scaling up a printer are:
And then there is the filament feed mechanism. The direct method is the best, but the heavier the extruder, the more energy it takes to move it. The Bowden system is interesting, but you have a long run of filament to push to get it to extrude properly, and it's a problem with flexible filament. Try pushing a rope sometime.
Yes, bigger printers will use more filament. But only if you print something big. A big printer gives you that option.
I learned most of this working on the design of the big (3' x 3') pen plotters. 3D printers are just plotters with a Z axis.
Anyway that's my take on 3D printers. They're useful coupled with a really good 3D CAD package. Otherwise, they are just a toy (or an interesting hobby).
Anyway, that's probably more than you wanted to know.
Steve
- Frame stability-You need a different frame design to prevent frame movement. Frame movement will absolutely destroy a decent print.
- Motion mechanism-The larger you go, the more the notched belt-stepper motor arrangement becomes problematic. Belts stretch, and the more side thrust on the motor bearings, the more problems they will be. Long belts are asking for slippage. You need some sort of linear motor or anti-backlash ball screw arrangement.
- The longer the rails (for the axis carriages), the more chance of bending. Bigger rails just add mass to the structure. More mass=more energy to move that mass and more strain on the motion components.
- All of the current RepRap printers are open loop. The only way the software knows where the extruder is is by counting steps. For a bigger printer, you need a closed-loop design where you get position feedback. When you have that, stepper motors only get in the way, and servo motors are they way to go. Then you need a complex controller, like a PID controller.
- Bigger heated beds-you need a good means of getting a uniform heat across the bed, probably using multiple heaters and multiple thermocouples. The big Chinese printers don't do this (single thermocouple). And you need a thermal camera to check out the heat distribution.
Steve
