- Nov 27, 2010
- Location
- Copenhagen Denmark
- Canon MP990
If the cleaning damaged the print head further I cannot tell. Hopefully no Windex residues damaged the logic board. I think you should do no further printing with the defective print head, not even a nozzle check, to minimize the risk of damaging the logic board, so your chances of successfully reviving the printer are increased.
Hopefully the refurbished print head will bring your printer back to good working order. The iP4500 is much higher build quality than subsequent Canon printers. See this: http://www.printerknowledge.com/threads/lubricant-for-printer-carriage-mechanism.4966/
If you intend to do extended nozzle checks from service mode, to see if all nozzles are working, you should be aware that the service manual contains an error regarding service mode operations, an important step in the procedure is missing. More info here: http://www.printerknowledge.com/threads/warning-error-in-some-canon-service-manuals.6388/
