These - http://goo.gl/w060ghwellsjr said:What kind of cartridge are you using?
Yes, I use Inktec ink.ghwellsjr said:Do you refill? If so, what kind of ink?
through the topghwellsjr said:How are you refilling? Traditional through the top of the reservoir or German refill method?
I tried the wet paper towel method with warm distilled water, window cleaner on the screen for the cyan nozzle and also on the larger purge pad and I even ran warm tap water onto the print head from both sides but I still get the same pattern every time. Do you think the nozzles are still clogged, or could it be electrical problem? What should I try next?ghwellsjr said:Have you tried any of the suggestions that were made throughout this thread?
