For those who have read my replies in regards to the Rubber plug (http://www.nifty-stuff.com/forum/viewtopic.php?id=3348&p=1) would have read about me mentioning the obstruction created by Canon for CISS users.
As such, nowsaday the Canon CISS non original canon cartridges in the market are usually slightly shorter in height than the Original Canon Cartridges. Generally there are 2 type of shorter CISS non original canon cartridges, either they are spongeless or with sponge. Currently, most spongeless one are still unstable while those with sponge cartridges some works slightly better than other.
For those who DIY CISS using original Canon cartridge (since the original canon cartridge tend to offer the overall best performance for refilling), they will inevitably have to mod their printer casing to minimize the obstruction when the carriage unit moves. I asked martop's help to capture images of the underside of IP4500 case cover as he was going to open it up to remove paper clip which had fallen into the printer so that I could highlight those area of obstruction on IP4500.
Below is a picture of where these obstructions on IP4500 are which will need to be remove should original canon cartridges are going to be used with the CISS.
As my IP4500 is still under warranty, I cannot touch that machine. So here is a case cover on my another machine with much less obstruction to show the before and after effect of the mod to give some idea how they will looks like.
Personally, if you are a causal user, and do not print huge volume per week, there is no reason to go CISS. All you have to do is to buy several sets of empty original canon cartridge and refill. Once any carts gets empty/low, all you have to do is to replace with a ready-refilled cartridge. Then place the used cartridge aside and leave it during the weekend or when you are free to refill.
Even if you only had one set of original canon BCI-3/5/6/CLI-8/PGI-5 cartridges, it only takes ~1 min to refill one cartridge with no hassle.
Before going CISS on Canon, think seriously if you really need to. Majority is still better off with refilling.
