inverse printing !
Saleh_chz
The word monochrome usually means black in print terms so this type of printer would be called a single colour.
you instruct a new lesson to me. thank you.
If you need more than one printed color at a time then have two or three of these printers.
So where colors (inks) combine together ? first ink may dry before 2nd ink come !
and yet Handjet cant make a (for example) 30,60,90 pico liter drop . for example i need 30pl C + 60pl M + 120pl Y + 0pl K for making X color.
oh! do colors drops combine together in general printheads ????
can you not print the boxes before filling them ?
we don't packet boxes! the boxes reach us packed.
we cant open the boxes. we can rotate the boxes and print other side! but i dont want do this work!!
Saleh_chz So where colors (inks) combine together ? first ink may dry before 2nd ink come
These little handheld printers cant print coloured pictures for you, only individual spot colours.
As you clearly cant print the boxes before filling, the only other alternative I can suggest is to print your information
on self adhesive labels in a printer first then stick them to the boxes afterwards.. :)
Saleh_chz
hi
Good day.
The fact that we dont know that when , how many and what boxes come here.
and we cant print label. I am grateful from you for you suggestions.
i download several video from Xaar printheads . good technologies.
the printheads can print vertical.
2 pipes come from tank to printhead. coming and coming back inks.
i think the gravity has low effect on inks in these printheads.
i think i must do this work ! this work and this test is very rapturous .
what happen if i turn over a printhead in working ? damage ?!
what is Your opinion that i do this test with what type of printhead ? pizzo , thermal or ... ?
what happen if i insert ink with a few specified pressure ? damage again ?!
i must do this test !!!
Saleh_chz
As I said in the previous thread #4 all of these inkjet printers are not designed to print upside down
even using a CISS system with piezo heads.
Unless you invest in a specialised printer designed to print vertically then your tests
will not achieve any successful results whatsoever, I still think the label print is your best bet.
If you wait to receive your boxes then you can print labels just as fast as trying to print directly onto these same boxes..:)
Saleh_chz
hi
so what do i do for upward printing? :D
what is Your opinion that i communicate with manufacturers ?
thank you
Saleh_chz said:
hi
so what do i do for upward printing? :D The most convenient way is to use labels on any printer of your choice.
what is Your opinion that i communicate with manufacturers ? By all mean but even with modifications the end result with be very difficult to achieve.
thank you Your welcome.. .:thumbsup
J
jaydentyler25
Guest
"only one colour not monochrome"
dear , however inside the film tv show only being ink or not being ink inside the printing! is not it monochrome ?
i just make sure to ask increasingly more Questions in other holiday destination and wait for here.
say thanks a ton The Hat
your replies are really extremely helpful
