Interested in refilling cartridges for my Canon mp 610
esp
Yes I plan on buying the other 3. I put a orange clip over my now empty black. I did a deep cleaning a few times because of my clogged print head..
I had no idea you could get 3 dollars for each cartridge. Thanks for telling me that.
on30trainman
Philadelphia, PA area
Just to be clear - you get a $3 Staples credit, not $3 cash. But it can be helpful. Used one $30 credit (10 cartridges) plus a $25 Chase credit card "Staples special certificate" to get a new Canon LiDE 200 scanner for $45 this past summer.
Also, there are some small lots (10 or so) of empty CLI-8 cartridges on E-Bay right now. E-Bay is where I picked up my empties for refilling about a year ago.
Steve W.
esp
But I have to make sure the Canon Cartridges and what about if there dried out? I assume there a procedure for that?
on30trainman
The ones that I am referring to are genuine Canon OEM cartridges. The dye based ink cartridges are fairly easy to purge (clean out). I refill using the top hole method and remove the plastic ball from the top of the cartridge. That makes purging very easy. Not sure how easy purging is with the German refill method.
Steve W.
Esp:
The following was written some time ago and not all of it may apply or apply to you, but it should answer a few of your questions.
The following is a compilation of previous posts to help you get started refilling.
A) Refill Ink
Anyone of the following will give good results:
http://www.inksupply.com/ selling MIS inks(reported to be Ink Specialty inks)
http://www.precisioncolors.com selling Ink Specialty inks
http://hobbicolors.com/ selling Hobbicolors inks
http://www.inktec.com/english/main.asp fot InkTec inks (Google "Inktec" for retailors)
Aftermarket ink from these retailors can be added to and mixed with Canon OEM ink still left in the cartridge.
Advanced User Tip - If you want the best color output then you will need to purge the Canon OEM ink out completely (see below) (or run a couple cartridges full of the aftermarket ink to wash out the Canon OEM ink), refill with one of the inks listed above, then obtain/purchase an ICC Printer Profile for your printer, ink and paper combination. You can purchase one from places like http://www.cathysprofiles.com/. Many casual hobbyists do not purchase an ICC Printer Profile and are satisfied with their color output. You'll know whether you're happy with the colors in your photos after printing out a few pictures. Much has been discussed about ICC Printer Profiles in this forum. Do a search if interested.
CAUTION: Some bulk ink retailers sell a "pigment only" black PGI-5 ink and/or a combination "pigment plus dye" black ink for the PGI-5. Make sure to get the "pigment only" PGI-5 if you want the best results, particularly for highlighting. It will cost a bit more but has the best chance of mimicking Canon OEM PGI-5 ink.
B) Refill Methods
Most people recommend using only Canon cartridges/chips for refilling as they are well made and last a long time with less risk of failure. Having a spare set is a good idea too as this helps decrease lag time in printing when you need to refill and swap in a fresh cartridge on demand (which always seems to happen in the middle of a print job you need to expedite).
There are several methods for refilling cartridges. You could vacuum refill - search for it in this forum. Several people on this forum use vacuum to refill with excellent result, though I think it is better for higher volume refilling than one cartridge at a time like most hobbyists. Then there are the two basic needle and syringe methods of refilling - a standard hole in top of cartridge method or the Durchstich/German method with hole on side towards bottom of cartridge. You can search for both methods in this forum as well.
If you prefer the standard method of refilling, then start by looking at the threads found in the "Refilling Inkjets" Forum. In fact, most all the knowledge you seek is contained within that forum. Whatever isn't will be added when the resident brainiacs, inventors and/or problem solvers figure it out.
A link to the text instruction for the Durchstich method at http://www.druckerchannel.de/artikel.php?ID=1830
A link to instructional videos on both standard and Durchstich methods of refilling plus on about purging cartridges found in post #7 at http://www.nifty-stuff.com/forum/viewto 45#p13145.
C) Cartridge Purging
Purging a cartridge entails running water through the cartridge to flush out old ink. It is useful if you change inks and do not want a mixture of previous brand ink with new brand ink, crud inside the cartridge, the cartridge is old and ink has dried up on the sponge which could impede ink flow, or there are streaks or missing ink when printing from poor ink flow out the cartridge for a yet unknown reason(though this could be a printhead issue).
A text version on purging cartridges using Grandad's Method is at http://www.nifty-stuff.com/canon-BCI-6-cartridges.php
Here is the equipment I put together for purging Canon CLI-8 and PGI-5 cartridges that evolved from that discussion:
Purging unit parts from Hope Depot.
1) 3/8" inner diameter clear vinyl tubing (outer diameter 1/2"), 3 feet ~$1.00 worth.
2) One Sweeper Nozzle, Model 56171 at Home Depot, $2.97 (similar to but with some plastic: http://lawn-garden.gillroys.com/Hoses_ &_Sprinklers/Hose_Nozzles/ BRASS_SWEEPER_ NOZZLE-s761223.html) . This screws onto my utility sink's threaded fawcet like a typical garden hose would.
3) One Hose Clamp 7/32" to 5/8" to secure #1 to #2.
4) 2mm hole drilled into the top of the spongeless area next to the edge of the decal (near where the ball is located) to let the purge water out.
The flexible tubing easily fit around the exit port of the cartridge. Warm water washed the sponge clean in well under one minute and I have no ink on my hands. I held onto the cartridge and directed the purge stream down the drain hole, but any ink in the sink washed completely out without staining.
D) Glue Gun Use For Sealing Purge Hole
1) Let the glue gun heat up to the proper temperature. This will cause a lot of waste glue to drip out on some guns, but the glue you do shoot will be hot enough to get he job done.
2) Don't use really old gluesticks that have "spoiled".
3) Use the right kind of gluestick, don't use wood glues for plastic cartridges for example.
4) Make sure the glued area is clean. Wipe off ink residue and peel away old glue if refilling a previously glued cartridge. It also helps to slice drill residue off the hole with a razor blade, as the plastic shreds can interfere with sealing.
5) Glues have different "open times" so allow the right amount of time for the glue to set.
6) For sealing holes on drilled cartridges, shoot a tiny glob to plug the hole, let sit for a few seconds, then shoot a secondary "sealing glob" over the plugged hole. Press the sealing glob flat with a flat heat resistant metal object. It helps to use a non-stick spray on your pressing object to prevent glue from sticking to it. I have found this method to be very effective in preventing leaks.
7) To remove the plug for later refilling, simply use a small needlenose pliers and peel off/pull out the glue.
E) Cartridge Resetters
There are a couple of different models of cartridge resetters now available, one from China and one from Germany. The Chinese offering is a relative unknown but may be perfectly fine. The one from Germany appears to have gotten the most press and reviews and therefore appears to be the one to consider at this time. The German model is offered at http://www.patronenhandel.de/index.php/ etter.html or on eBay at http://stores.ebay.com/magic-chip. I do not know if these two businesses are related or even if the resetter they sell are identical, but it seems they might be from anecdotal reporting here.
It is another matter entirely if a resetter is necessary, especially given your financial state. People have been "eye-balling" their ink levels for years and not experienced a printhead failure from no ink while printing. It is, like most things, personal preference and money.
F) Ink Level Monitoring
Simply take the cartridge out and visual inspect for ink in the spongeless side. Until you are confident, refill your cartridges just before or just when the spongeless side is empty of ink. The sponged side will always appear to have ink left in the sponge, never turning completely white and free of ink - I have heard that up to 1 ml of ink remains in the sponge even when Canon declares it empty. Best not to tempt fate, though if you do, when a color startrs streaking or missing you will know the ink is used up (OR you have developed a problem like a clogged or burned out printhead). STOP printing and refill!
Removing the cartridges in order to refill or inspect ink levels will initiate a cleaning/priming cycle after the cartridge(s) are returned to the printer. Canon's purge much less ink than Epson's, and, with bulk ink the money loss is minimal.
To cut down on these initiated ink purgings, there is a novel way of visually inspecting ink levels WITHOUT removing the cartridges. Read about it at http://www.nifty-stuff.com/forum/viewtopic.php?id=2492.
Also, there is a clever program developed by a poster on Nifty-Stuff that keeps track of print jobs and helps alert you when ink is running low depending upon how YOU set it up. The program can be found at http://inkmon.org/.
For all these seemingly overwhelming instructions/tips, refilling a Canon ink cartridge is as simple as poking a hole in the cartridge, filling it with ink from a syringe and needle, and sealing or not sealing the hole (depending on the method used). The process takes 2-3 minutes per cartridge once you've done it a couple of times. Cost is about 10-15% of an new OEM Canon cartridge per refill.
esp
I ordered some of the Inktec for a empty Black cartridge I would like to refill. Does the inktec come with a needle long enough for the german method?
Is the main difference between the German method and filling with the top hole is that with the german method the Sponge gets saturated? Which means longer times between fills.
I have been reading alot on both methods and the procedures but none that have went in depth of there pros and cons.
The Inktec refill kits come with very short needles and a bunch of other stuff that you will not need if you refill with the German Refill Method. I recommend buying just the small bottles/syringes if you plan to refill with GRM. You can buy 2-inch needles and scabbards from Howard Electronics. I recommend the 18 gauge needles. Also click on the link in the upper right corner to get scabbards or needle covers (I don't know what the difference is between them). EDIT: on closer examination of the pictures on the website, I can see that scabbards are what are needed to seal the end of the needle. The covers go over the whole needle down to the stem but they aren't long enough for 2" needles so they are useless in this application.
The main advantage of GRM is that you don't have to worry about sealing the hole that you put in the top of the reservoir for the traditional method. The traditional method will saturate the sponge much more than GRM. Ideally, you should only saturate the bottom half of the sponge chamber which in a Canon cartridge is made out of a different material than the top half which needs to permit air flow. You can get more details here. Read the whole thread if you want to learn more about the differences between the traditional and German refill methods.
billkunert
Georgetown, Ky
HP Envy 5530e
I've been using ink from inksupply.com for years, through at least 6 printers and have always been pleased with the results. I now have a MP-600 and have refilled many times. Inksupply is now selling empty PGI5 and CLI8 compatible carts for refilling without chips. They come with a fill hole and a plug in the resevoir side. I bought a set of 5 but haven't tried them yet. They seem very well made.
esp
Will the needles fit on any syringe? Because I don't see any syringes that they sell. I only see kits that include the barrel portion http://www.howardelectronics.com/jensen/needle&syringekits.html .. I want to buy a few to go with the needle. I might try the bottles also.
Or do those needles fit right on the Syringe/bottles I get from Inktec?
Yes, the needles fit on any syringe including the Inktec bottles/syringes.
You can get the syringes here. I would suggest the 20cc size. EDIT: On second thought, maybe 20cc is a little large, you might want to go with 10cc.
