qwertydude
- May 7, 2009
To refill the NX110 you're going to need to buy refillable cartridges with some sort of auto reset chips. Inkwise I haven't had too much trouble with the cheap ink from ebay, they actually formulate it for different Epson printers, or at least label it for each printer. It is a dye ink though so not compatible with the pigment ink in your oem cartridges even if you could refill them. At least for my Artisan 50 the color accuracy to OEM Claria is darn near spot on.
http://cgi.ebay.com/800ML-2SET-REFI.../270462220826?pt=BI_Toner&hash=item3ef8cdfa1a
As for the cartridges make sure to get empty, damper style cartridges. These are usually identifiable as the cartridges with two rubber plugs. One is for the refill hole and the other is the priming plug.
