Cary
- Sep 3, 2015
- Location
- Hawaii
- UV flatbed printer China
After resolving a different issue with my printer and letting it sit for a week, My current problem is getting the ink to flow through the dampers to the print head. Here's what I've done
1. replaced all the dampers which needed to be done anyway. Problem was happening before replacing dampers. I also primed each of the new dampers by pulling ink through the outlet on the damper.
2. Multiple power cleans and NO ink flowing from any color.
3. Put solution in capping station and pulled it through the waste ink line. No blockage
4. When I run a power clean I can see air bubbles coming from the line into the waste ink reservoir so I assume the pump is working.
Thanks for any other troubleshooting tips!
