Sirman
Mayby the only cheap solution ???? -
7 MARCH 2008 : below here is not the complete all there is , pls take a note and read more ideas for experiments in other paragraphs to ...
I just looking for a cardrige solution ( Canon IP4300 ) because 4/5 cardrige leds are dimmed off and need to be replaced . I just order 5 adopters ( not for this idea ) and 5 new with a new chip for all five ink cardrige . Wellknown problem : The chips uses memory and this makes it very hard to reset . But i have thinking .. mayby this is somthing ..
What you read is never done before , experimenting with this idea is all at your own risk !
Here is a simple markable solution Unique !!
A - First you need (all 5) brandnew cardrige(s) with chip(s) ( please keep all ink preventions inplace )
B - 4 poles - 2.50 meter +/- telephone cable
C - (five) (new) OEM cardrige without chips
D - Tin and a somthing to solder
E - (5) old chips using for adopting the connection to outside the printer
F - A box for the 5 new chiped cardriges
Procudure :
1 ) Make of +/- 2,50 meter 5 pcs of 50 centimeter
2 ) Solder the cable of lengt to the old chip but first remove all the (useless) electronic components and cirquite and place it on the OEM cardriges (this is now functioned as adopter)
3 ) Solder the other site of the cable to each new chiped cardrige cq / toner that still sits on the new orriginal cardriges ( our .. make a alternative feder contact if you dont want to solder )
4 ) Tape the 5 new cardriges together and *
5 ) Put it in the box and give it a save unremovable place **
6 ) Put the (5) oem cardriges with the just made clean old chip print (2) in the right ink location(s)
7 ) Now this is still to be tested but likely the printer now sees the external cardriges everytime and it stays filed !
* ) Looking into the new cardriges : this needs a box because of the intervering with the led this not only makes it nicer but mostly because of the outside light influence .
** ) Dont turn the kid upside down our shake it . If you do , the led indicates that the cardriges are empthy our low and the countdown proces for the chip will start !
I wait for the arrive of the new ones ( 7 days ) and for making it clear .. i am - NOT - intent to let - you - try and i wait for results , my thoughts : Comments in this all like to hear , and anybody who try please make a handshake !
See you soon
John
Netherlands
( posted this Idea on some printer sites today )
Procudure :
See you soon
John
Netherlands
