sfphoto
- Jun 16, 2023
- Canon imagePROGRAF PRO-300
I bought a used Canon imagePROGRAF PRO-300. I know, it was probably a mistake to buy a used printer, but I tried anyway.
Initially, everything looked fine, but then I noticed that the edges on the left and right of the photographs were blurry, not uniformly, but in a wavy pattern. I made my own test pattern and printed it to get a better idea of what was going on. It turns out that fine lines become double lines towards both edges (in any color). Interestingly, this is independent of the paper size, always at the edges, no matter how wide the paper is. Maybe there are some vibrations or so as the print head turns around at the edges. It looks like a ghost image overlayed at the edge, and its extent changes in a sinusoidal fashion along the edge. I have tried all built in tests and everything looks perfect (in the middle of the paper where all tests are done anyway). I am attaching a scan of one of these printouts on which I have marked the problematic areas in red.
Do you have any idea what may be the cause of the problem and how I could fix it? Thanks a million!
