I'm looking for used OEM 525/526 cartridges
zepat
Perols... south of France
canon MP620
I'm gonna try to upload a .zip file with the sound and who knows ... hahaha
Thanks in advance
Here we go ...
The sounds!!
  • Enregistrement audio 2018-05-03 09-17-23.mp3.zip
To me the noise sounds like gears slipping. The gears are probably related to the purge unit. Does the printer work normally after the sound has stopped? And is the nozzle check OK?
In case of a malfunctioning purge unit I would expect many clogged nozzles or even totally missing print.
I once had a purge unit problem with an iP4000. I don't remember the error message, but I remembered a tip to push down on the two small porous plates. I did and something clicked in place and the printer worked again. Before taking the printer apart you could try this and also clean the purge unit as suggested by The Hat in post #3.
zepat
canon MP620
I cleaned the pads as "the hat" suggested and it seemed to be much better.
The print head is perfect and the nozzle test has been perfect. I cleaned the print head before I used the printer with the "Pharmacist" Method. The print head has been reacting in a perfect way.
I guess I will have to clean the purge unit and take the gears apart..
Send you tomorrow a picture of the nozzle check.
Best and thanks for your patience.
zepat
canon MP620
Hello PeterBJ,
longtime ago not talked... ;-)
The noise has never stopped... I cleaned the pad under the gear wich was totaly full of old colors...
Printing is very ok...noozle test is very sucessfull Print head is in very good shape.
I try to send you a small video of the action.
Best regard
  • VID_20200319_092154.m4v.zip
zepat
canon MP620
@zepat, I got a set of 521/520 clean carts with no chips on them and a USB 526 resetter, if any of this stuff is any good to you.. :)
Oh that's very kind of you but in between,fortunatly I found at the recycling place in my neighbourhood, a bunge of OEM Canon 521/520 526/525 in good condition and I also do have a resetter. Thanks a lot for your post ;-)
I think the sound in the video is similar to the sound in the audio clip, so I still think it is caused by something being stuck or having too much friction and so causing gears to slip.
Since my last post in this thread I salvaged a Canon MG5350 and after a little cleaning it was OK. So I searched for a service manual but found none. But the MG5300 series is mechanically similar to the MG5200 series so I think an MG5200 service manual will also be useful. It has got a good disassembly instruction and apart from the top scanner parts the printers might be identical. You find working links to that manual and a collection of photos from dismantling a MG5350 in this thread.
Instead of gears slipping the noise could also be caused by a clutch not properly engaging, See this and this post.
Good luck with the troubleshooting. I think the MG5350 is much better than its successor the MG5450S.
zepat
canon MP620
Hello PeterBJ,
I have been trying to clean up the time stripe band and on the right side (pad,motor etc...) I noticed there was some strange stain of very old colours... It didn't run away with Isopropinol solution... may it be a cause of wrong informations read by the sensor?
What do you think about?
I try to make a picture of it.
Best regards
Zepat
If the timing strip is not clear and clean that could cause the noise you’ve described to occur…
The timing strip is vital for determining the position of the print head. It has some very fine vertical markings. These fine markings are read by an optical sensor. Stains on the strip will cause the sensor to skip some markings so the position is not accurate, so I think the stains near the right side end of the strip could cause the problems if the print head doesn't stop where it is intended to.
Pure isopropyl alcohol is not a good solvent for dried ink. A diluted alcohol is much better. A good solution for dissolving dried ink is pharmacist's cleaning solution that contains 20% alcohol. Window cleaners with ammonia are also good. They also contain diluted alcohol.
