I need the best order of operations to store a printer.
William Seaward
Romeoville, IL
Canon Pro 1, 10, 100
I asked this question several months ago and received the advice that I quoted above (not about the pro 1, as that printer has special requirements). I took the time to gather an extra set of cartridges to fill with Pharmacist's Solution and clean out the print head properly and then to store it... Now the wind says to just soak in water and put a "dab" of Pharmacist's Solution on it? I really don't get it... I guess I need to get an anemometer and add that to the mix. :)
@William Seaward, you did it one way and now you have found alternative way, and you won’t know till you take the printer out of storage again and try it, which way was right. :confused:
Just sticking it in a box as is also works for some...:ya
