Hi Everyone! I am having trouble refilling the HP701 cartridge. It has two chambers. 2/3 of the cartridge is just an empty space for liquid ink. The chamber closest to the printhead has a sponge. I think the empty chamber has a small hole at the bottom so that the ink will flow to the sponge in other chamber. It also has air vents near the top rim of the blue cover where the ink is. The problem is instructions say to make a hole in the middle left portion of the cover and inject the ink. This hole goes into the empty ink chamber. I did this and I also tried injecting directly into the sponge but the ink still not flow out of the printhead bottom.
Also when you tilt the cartridge the ink comes out of the air vents. the fax machine also does not recognize that you already put a cartridge into the fax machine. If I use a new full cartridge I don't get this problem.
So my question is, what the correct way to refill the ink and where do I punch the hole? 2nd question is how do I get the fax machine to recognize that that cartridge has been installed. Even if I tell the fax machine that I installed a "used" instead of "new" cartridge, it still does not recognize it and keeps insisting that I install a cartridge.
Please help.
Thank you.
Please help.
Thank you.
