- Oct 27, 2005
- South Yorks, UK
- Epson, Canon, HP... A "few"
I had a look at the first kit a bit more carefully and the one you just linked to from eBay and noticed a couple of things you might want to check on.ink-solutions said:I am going to order it then a see if it helps. I have also see a next type on ebay, this one claims to be better:
http://www.ebay.com/itm/HP-940-88-p...=350578512699&ps=63&clkid=1684848157865908075
1. The first kit is more involved with that split funnel creating a very real potential ink spill/mess that is hard to ignore. Bit concerned they went that route as it's just asking for trouble. I neglected to spot the funnel before so mea culpa and a withdrawal on my whole "DIY" suggestion...
2. The second kit with tubes is a more elegant solution on that front but the lack of attention to the description makes me think it's a reseller with very little clue as to the actual kit itself so I'd look for an alternate purchasing source for the same thing. The key things you'll want to check for are:
- length of those tubes
- can the tube be flexed to dip into a bottle of ink so you can reprime
- any instructions you can check out first so you can see how they work
... without that I'd have some qualms about the suitability of the kit without needing to do some retroactive modification to make the whole thing workable.
All in all, nice ideas there but I can't help but think the whole lot could have been put together and thought through somewhat better...
