- Thread starter
- #11
Thanks again for a prompt response fotofreek,
I do believe your conclusion that I am doing things correctly is right. Given two facts.
(1) Even though the refilled cartridge sponge shows 100% color infusion when using hobbicolors ink, zero liquid ink shows in the air gap between the top of the sponge and the top of the cartridge body.--which in my mind means that the sponge will absorb as much ink as possible without over saturating (2) No ink drips from the ink outlet hole after the ink inlet hole is sealed.
But as I write this post I see grandad35 has weighed in and removed some more doubt in my mind.------and that the difference in sponge color infusion in the 80-90% sponge color infusion of an OEM or a third party prefilled cartridge and the 100% sponge saturation I experience is likely due to the probability that a refilling through the ink outlet hole method is used. And the resulting cartidge may be somewhat shorted in ink content.
But I still am puzzled why such a cartridge refilled through the ink inket would not over a short time allow ink to be absorbed into the sponge from the reserve tank.--100% color saturating the sponge--even if sealing the air vent prevented that process---when the tape is removed from the air vent and the cartridge is inserted into the printer--would not that absorbtion into the sponge process then restart and result in a 100% color saturated sponge in a matter of a minute or so?
The alternate hypothesis might be that hobbicolors ink just saturate the sponge better.
But whatever---maybe I am just trying to understand the psychology of a depleted
canon cartridge-----that has magically been resurrected from the dead---and succeeding in only driving myself crazy.
But as I mull over that last sentence, I think I now finally understand the difference in refill methods-------in the vacuum fill through the ink outlet hole the ball above the reserve tank only allows air out as ink replaces the air---whereas in home refilling methods the ink inlet hole the user creates and later seals allows air both in or out of the reserve tank during the refill process.--resulting in a vacuum in the reserve tank that prevents the sponge from being able to as readily absorb ink from the reserve tank in the former case of vacuum fill through the ink outlet hole method. Which would also perfectly explain the difference in sponge color infusion between the two methods.-----with 100% color infusion actually the ideal case.
