headphonesman
- Mar 18, 2006
All of the foregoing involving screws , o rings , tape, clear sealant, etc. have their merits, they all work given its a bit fiddly.
My current method is using the little rubber bungs of various sizes provided with the reifill kits. these are of variable quality and robustness, and will soon need to be replaced by an alternative method. I was favoring the screw / o ring method to go forward.
I have also used previously a glue gun......but its a pain chipping the glue back off....and switching on and using the glue gun , switching back on again etc........but it works.
But in one of my re-fill kits was a small "eyelet" ? screw.....I think it was for hooking out the "plastic ball " (the one in the hole originally used by Canon to fill the cart , underneath the label). I thought if it could hook the ball out it might as well be used to put the ball back in.......again.!
I first scraped the label away exposing the ball, first attempt to start the screw in the ball failed....needed a "start" ....this was done by pressing the point of a Stanley Knife blade into it.......then screwing the eyelet screw gently but firmly into the ball (like a wine cork) untl it had enough purchase (about half in) and then lift...the ball comes out on the end of the screw , with a nice popping sound....(put to one side).Put the ink into the nice big hole. Take the screw , put the ball back in (nice popping sound), unscrew the screw from the ball, turn cart upside down and check no leakage from ball hole. Ball is ready to be unscrewed again provided care is taken not to overstress it. I currently have a half filled Cyan in the Garage that I am monitoring that i used this method on. I`m sure I have seen this method described before, correct me if you think I am wrong or the system is flawed...I shall probably be continuing with it when the bungs run out.
The eyelet screw is the smallest size that there is I think...?...about 1.5 cm long.
