Ghwellsjr, on the post #4 Pharmacist reported print head clog, not purge unit clog. In the post $5 you reported the purge unit clog. This was the first report of purge unit clog by Inktec pigment black ink and it was by you. In the post #6 pharmacist said: not only purge clog but--- He continued to talk about how the thought the ink clogged the print head. I can agree that he concurred about the purge unit clog. But technically he was not the first to report it. Had you not reported it first he might never mentioned about the purge unit clog at all. In fact in the post #4 Pharmacist said he wasn't the one who experienced the clog. He read of such report on a German site.
I am not debating about whether the Inktec pigment black ink will clog the purge unit or not. I am only trying to point out that you seemed to be the only one reporting about the problem. I am pretty sure I have used the ink and I did not experience the purge unit clog. I do understand what Pharmacist was talking about. I can tell you even the OEM BCI-3ebk ink was like that. Maybe it wasn't as bad as Inktec's. Have you noticed that some dried up BCI-3ebk cartridges need to be flushed or they will not refill well? This does not exist in any PGI-5. I think Inktec's old pigment black ink had a formulation similar to Canon BCI-3ebk. Perhaps it was not as good or perhaps you got a batch of bad ink from Inktec.
In the post #4 Pharmacist only reported print head clog. He did not say anything about purge unit clog. You were the first to report it on post #5. When you reported this I was surprised. That's why I remember you were the first to report it. You repeated the report many times. They really look like beating a dead horse after it's been dead. Sorry to describe it this way. But this was really how I felt. It was a questionable accusation to me in the first place. Then you said Inktec no longer has the ink. What's your purpose to keep repeating the complaint over and over if it is already discontinued?
Let's get the fact straight. It's good that you reported the problem. It helps others from getting the same ink and become victimized. However, it the ink is discontinued then let's check out their replacement ink. If it is a good ink we should use it. If not we can continue to condemn it. This is only fair and good for our pockets.
