duncan22
Having tried out other systems the German method is the one I now stick too but despite having refilled carts a number of times I still come unstuck with the odd one.
The problem is that the needle has not gone through the existing hole between the centre chamber and there is no way to tell exactly where the needle tip is... if it's veered to the left or right then you can see where it is against the outer chamber wall but you only need to be slightly out of line with the needle to miss it. Of course the needle can be withdrawn and reinserted and sometimes on the second or third try it goes through the hole so no problem but other times I have tried a dozen times without success.... perhaps I'm just clumsy, need even more practice or just both !
I Know there is no answer to a post like this but it might just be helpful to anyone else in the same position as me because despite the problems I have still saved a fortune on the replacement of ink carts.
Maybe one idea is to get an old cartridge and just keep practicing by filling it with water until I can do it blindfold !
