Hi folks
shadow
Ohio, USA
canon MX700
To be blunt you’re not using the best of cartridges or inks for that matter and the chip on these cartridge may not reset, so try this method.
Give this place a try for your inks and empty CLl-8 carts and a resetter so you can then reset all of your cartridges each time you refill them, there is also a refilling video on this site for you to familiarise yourself with a proper refilling procedure..
http://www.precisioncolors.com/
http://www.precisioncolors.com/Maintenance_Canon.html
I checked your links.
Joe toolman posted that I probably have a print head problem.
shadow
Ohio, USA
canon MX700
Welcome!
The correct flow stream shape when testing with a syringe filled with water would be a FAN shape will all nozzles showing equal amounts of spray.
Anything less than a clear fan shape indicates problems.
Joe
Thanks Joe,
The water is clear but no fan shape. I used hot water and also alcohol then air from my compressor. Can further soaking help at this point?
